TwinTurbo.NET: Nissan 300ZX forum - Pretty normal to have oil mist deposits in upper plenum.
Subject Pretty normal to have oil mist deposits in upper plenum.
Posted by jzack on June 11, 2018 at 6:02 PM
  This message has been viewed 285 times.
In Reply To 8mm water line plugs - where to find them? posted by 300NASeattle on June 11, 2018 at 05:02 PM
Message Not really necessary to clean it up. I’m anal so I did mine years ago - lots of rags, good flashlight and 2 cans of throttle body cleaner. Needed to wear a 3m spray painting mask too and definitely did outside.
I’d also recommend doing the valve covers seals since all is apart along with the exhaust cover rear half moon seal plugs. Check the spark plug cavities too - make sure no oil is leaking in there.
Sorry - it’s been years, don’t remember where it got my coolant line caps for the bypass.
PS - there’s a trick to applying extra dabs of RTV to assist the intake valve cover gaskets. So post if you need more info for that...
