TwinTurbo.NET: Nissan 300ZX forum - Static Leak Check: Connect rail to fuel lines but don’t
Subject Static Leak Check: Connect rail to fuel lines but don’t
Posted by jzack on June 02, 2018 at 10:47 AM
  This message has been viewed 434 times.
In Reply To Re: If all done right the new style should not do that. Have >> posted by Lowlife1998 on June 02, 2018 at 09:58 AM
Message bolt rail to block. Turn on key to pressurize the rail and check for fuel leaks. Rail is pre-start pressurized for 2 seconds when key is first turned.
Given they are used injectors - having 1 leak isn’t much of a surprise. There’s no way injectors can really be reconditioned or repaired. Just flow tested and cleaned a little by running some cleaning fluid thru them.
