TwinTurbo.NET: Nissan 300ZX forum - Re: Input shaft bearing noise 92 300ZXTT
Subject Re: Input shaft bearing noise 92 300ZXTT
Posted by ZBOOSTT on May 27, 2018 at 2:32 PM
  This message has been viewed 300 times.
In Reply To Input shaft bearing noise 92 300ZXTT posted by ZBOOSTT on May 25, 2018 at 03:01 PM
Message Ugg. I thing the whole tranny needs to be taken apart to get the bearing. It is making the whirling/chatter sound that goes away with clutch all the way down and it stops making noise in 5th as the bearings are rotating in unison. I need to replace my Z1 flywheel as well as the starter teeth on the flywheel are busted off. Less than 3K miles. Going back to stock flywheel and replace the throw out bearing while I'm in there. I can't tear down a tranny and fix those. No press or giant long bearing pullers.
