TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Yes, that is the normal way. Why would you pull the engine..
Subject Re: Re: Yes, that is the normal way. Why would you pull the engine..
Posted by itsa300zx on May 25, 2018 at 2:32 PM
  This message has been viewed 296 times.
In Reply To Re: Yes, that is the normal way. Why would you pull the engine.. posted by ZBOOSTT on May 25, 2018 at 01:21 PM
Message A couple things I do to make the top 2 bolts easier:
-disconnect the 4 boost hoses in the front.
-loosen up the two motor mount bolt.
-Do not need to touch the heater hoses.
Once those are done and the trans brace is removed, the rear of the trans will sit low enough to access the bolts with a 36" extension.
