TwinTurbo.NET: Nissan 300ZX forum - Re: Vacuum leak or something else?
Subject Re: Vacuum leak or something else?
Posted by ZBOOSTT on May 25, 2018 at 1:31 PM
  This message has been viewed 286 times.
In Reply To Vacuum leak or something else? posted by KeepinitClassy on May 23, 2018 at 05:29 PM
Message It could be a giant number of things. Timing belt off a tooth, injectors not working, fuel pump, computer, vac leaks, turbos, and many other things... Need to plug it in a ConZult at least to see what is all working or not on the electrical side, and compression test. He should have put in a new wire harness. A bad wire harness has to go. I'd run away from that car fast. Find something running.
