TwinTurbo.NET: Nissan 300ZX forum - Re: Yes, that is the normal way. Why would you pull the engine..
Subject Re: Yes, that is the normal way. Why would you pull the engine..
Posted by ZBOOSTT on May 25, 2018 at 1:21 PM
  This message has been viewed 281 times.
In Reply To Yes, that is the normal way. Why would you pull the engine.. posted by itsa300zx on May 25, 2018 at 09:49 AM
Message Because the tranny bolts are really hard to get to. The top bolts. Do you go over the top of the tranny from the back to get those? I did that once with a 6 foot extension, but could not see the bolt, just blindly trying and finally grab the bolt with a swivel socket. The heater hoses are in the way. Just remove those, but I guess I'm wondering if I will need to tilt the engine. I have solid motor mounts, so that is an issue if I need to tilt it. I have to do this all myself. My Z buddies have all moved away. ;(. Thanks very much for your response. Good time to put in my AshSpec radiator I guess too. Any advice to look out for guys? Think I should replace my flywheel bolts after reusing them 5 times now. Clutch bolts too? Thanks all
