TwinTurbo.NET: Nissan 300ZX forum - its bad alternator/voltage regulator,bad connection,or short
EngineerLV
on May 24, 2018 at 10:09 AM
Bad alternator, relay, or something else?
posted by OverZealous (CT)
on May 21, 2018 at 07:58 PM
Belts slipping and making noise because alternator is under extreme load. Need to figure it out soon, mine ruined my ecu, ac controller, and battery. Ended up being a cheap alternator rebuild in my case. Costed thousands in the end.
OverZealous (CT)
19:58:59 05/21/18
Re: Bad alternator, relay, or something else?
SkiFly01
11:55:29 05/22/18
A surge/overcharge is anything above 14
FrozTTy
11:58:31 05/22/18
With engine at normal idle and headlights on the voltage
jzack
12:03:11 05/22/18
bulb check relay is behind the fuse box in the kick panel
compirate
16:01:47 05/22/18
its bad alternator/voltage regulator,bad connection,or short -
EngineerLV
10:09:06 05/24/18
