TwinTurbo.NET: Nissan 300ZX forum - I thought the worse case scanario was the engine would just
Subject I thought the worse case scanario was the engine would just
Posted by jzack on May 23, 2018 at 11:35 PM
  This message has been viewed 310 times.
In Reply To Possible damage by not fixing immediately...? (n/m) posted by GrecV2 on May 23, 2018 at 03:25 PM
Message perform poorly since the ECU would think timing was adjusted a certain way (and map for that) while in reality the leak may keep the VTC from adjusting.
Not sure it's severe enough to damage the engine (knock) under boost? Others can chime in???
But if you've already got a things apart to see the leak what's the big deal in replacing the gears?
