TwinTurbo.NET: Nissan 300ZX forum - Re: Wait... are you trying to do a boost leak test?
Subject Re: Wait... are you trying to do a boost leak test?
Posted by trond on May 23, 2018 at 8:49 AM
  This message has been viewed 307 times.
In Reply To Wait... are you trying to do a boost leak test? (n/m) posted by GrecV2 on May 22, 2018 at 08:58 PM
Message Yes, I want to test the lines from the airfilter and block the manifold inlet so I can pressure test the turbo, intercooler and lines for leaks.
I think I might have a leak that comes with pressure from the turbo and 5 psi is not enough to test.
The wastegate is set at 0,9bar but I can only get 0,7 bar. So need to test and need pressure to test. 5 psi is not enough.
