TwinTurbo.NET: Nissan 300ZX forum - With engine at normal idle and headlights on the voltage
Subject With engine at normal idle and headlights on the voltage
Posted by jzack on May 22, 2018 at 12:03 PM
  This message has been viewed 247 times.
In Reply To Bad alternator, relay, or something else? posted by OverZealous (CT) on May 21, 2018 at 07:58 PM
Message across the battery terminals should be around 14v. It sounds as if the alty internal voltage regulator/diode bridge has failed. This failure can allow excessive battery current draw when the car is off.
With car off, all doors closed, all lights off, etc - the battery current drain should be no more than ~40mA (.040 amps). With a bad alty it will read 500mA or so. Draws the battery down easily overnight since alty isn't charging it property when car is running.
A rebuilt alty can be ordered from a local car parts store. Just a quick eBay search showed a good selection from a variety of sellers. This sites parts sponsors should have them too.
