TwinTurbo.NET: Nissan 300ZX forum - Since you've done the 120k service the plenum pull isn't
Subject Since you've done the 120k service the plenum pull isn't
Posted by jzack on May 19, 2018 at 8:07 PM
  This message has been viewed 351 times.
In Reply To I should have said fuel rail to intake O-ring posted by 300NASeattle on May 19, 2018 at 02:09 PM
Message any worse to do. You are now experienced enough to do the pull but just realize there's a lot of things worth attending to while it's off. Valve cover seals, injector connectors, delete the under plenum water lines, fuel hose that connects the 2 rails together, etc.
Really just time consuming more than hard. Also actually pulling the plenum off the engine goes better with another set of helping hands....just awkward.
