TwinTurbo.NET: Nissan 300ZX forum - Broken fuel injector o-ring - air leak video
Subject Broken fuel injector o-ring - air leak video
Posted by 300NASeattle on May 19, 2018 at 1:56 PM
  This message has been viewed 343 times.
Message Hello,
I purchased an endoscopic camera that plugs into my phone to see if I could determine the cause of the air leak around the number 2 cylinder on my 1995 NA.
It looks like the vacuum leak is around the top of the #2 fuel injector. I am not sure how that is possible without fuel flowing out of the same area. I had a 1993 NA before and replaced a few of the injectors using the Dremel method and what I remember of the injector and what I see looking at all the injector pictures online I do not see any o-ring that would be visible above the fuel rail. The upper injector o-ring should be below the surface of the fuel rail surface.
Here is the video,
Just in case the embed does not work for you, here is the direst share link,
https://photos.app.goo.gl/PNitkjBlOrG9vHf33
