TwinTurbo.NET: Nissan 300ZX forum - valve noise solved
Subject valve noise solved
Posted by Dean-o on May 18, 2018 at 4:18 PM
  This message has been viewed 410 times.
Message My 1994 300ZX TT, at 115,000, was developing increasing valve noise. Consulted Concept Z in Phoenix, and trusted local mechanic, and then blended their advice.
1. Half a can of Sea Foam into oil, half into gas, drive 200 miles with 3000 RPMs a good part of the time, within a couple of days.
2. Drain or suck 1 quart of oil out.
3. Add 1 quart of Dexron ATF, drive 8-10 miles.
4. Drain all oil, remove filter.
5. Fill with Castrol 10/30 (non-synthetic), new filter.
6. Listen with stethescope. Noise gone.
Worked for me. If not better, repeat. Or, pull the top off and spend some money. Your choice.
