TwinTurbo.NET: Nissan 300ZX forum - I drilled a hole around 1/2 to 3/4" in the belt cover
Subject I drilled a hole around 1/2 to 3/4" in the belt cover
Posted by xpwarrior on May 09, 2018 at 8:00 PM
  This message has been viewed 350 times.
In Reply To Check auto-tensioner gap - an easy way? posted by ZUL8R on May 07, 2018 at 11:51 PM
Message so I can look down between the pipes and see the gap in the tensioner at any time. It was a little tricky figuring out where to put the hole but to me it was worth it. I started to hear some noise one time and able to see that the gap in the tensioner was completely closed up just by looking through the hole. Ended up being that the arm on the tensioner had seized up and I was able to find it before having any other problems like jumping teeth.
