TwinTurbo.NET: Nissan 300ZX forum - Re: Upper radioator hose collapsing...?
Subject Re: Upper radioator hose collapsing...?
Posted by wh0sjeff on May 06, 2018 at 4:38 PM
  This message has been viewed 310 times.
In Reply To Upper radioator hose collapsing...? posted by GrecV2 on May 06, 2018 at 10:34 AM
Message check your radiator cap. as your coolant gets hot it expands, reason you have an overflow tank and when the coolant cools again it shrinks and it will cause you hose to collapse. the cap is usually the culprit if you cooling system can't breathe. hope this helps
1
