TwinTurbo.NET: Nissan 300ZX forum - Re: Help! Clutch pedal collapsing, no pressure
Subject Re: Help! Clutch pedal collapsing, no pressure
Posted by Metacom on May 04, 2018 at 8:00 PM
  This message has been viewed 352 times.
In Reply To Help! Clutch pedal collapsing, no pressure posted by robsheer on May 04, 2018 at 03:54 AM
Message Replacement slave cylinders are cheap, grab an exedy or rebuild it.
I had that same problem when I replaced the clutch, clutch master, and bled the lines on my TT. For some stupid reason I couldn't get a trapped air pocket out. I loosened the lines connecting to the master and had a helper push and hold the pedal and bled through there.
I am using speed bleeders for the clutch lines...
Then I bled through the slave banjo bolt connection and retorqued the banjo to rest in a more neutral position and then did the normal bleed procedure. I'd also tapped up and down the lines to try and jar the air pocket loose.
Then a gravity bleed at the slave. Think I went through a whole 32oz bottle of DOT3 lol, but it worked.
