TwinTurbo.NET: Nissan 300ZX forum - Low Idle/Stall/Chirp
Subject Low Idle/Stall/Chirp
Posted by FrozTTy on May 03, 2018 at 12:25 PM
  This message has been viewed 416 times.
Message HELP - this is driving me nuts:
Z will have a low idle on start-up (even when cold) around 750 RPM's.
Also hear a slight 'loose belt' noise upon start-up for a couple seconds.
While driving and coming to a stop, if I press the clutch pedal in, the RPM's will drop quickly and act as if going to stall (and has actually stalled a couple times). It will drop to about 500 RPM's and if I punch the gas to keep it going I will hear a "chirp", like a squeaky belt type noise.
Some days are worse/better than others, but it is pretty consistent (bad) at this point.
HELP!!!! Thankz
