TwinTurbo.NET: Nissan 300ZX forum - Re: Lightweight aluminum pulley squealing?
Subject Re: Lightweight aluminum pulley squealing?
Posted by Rob260 on April 25, 2018 at 4:15 AM
  This message has been viewed 433 times.
In Reply To Lightweight aluminum pulley squealing? posted by cosmonautpetrov on April 23, 2018 at 09:45 PM
Message Not surprising, a polished ally surface is going to be more slippery than the surface on the original pulley.
Do you have a belt tension gauge? A Krikit type gauge from Gates or Dayco is cheap and easy to use and you can usually get the tension right on the first go.
You do not want to go on tightening indefinitely as it is very easy to damage the water pump.
