TwinTurbo.NET: Nissan 300ZX forum - Re: Any reason NOT to crack 19mm intake cam bolts before...
Subject Re: Any reason NOT to crack 19mm intake cam bolts before...
Posted by Rob260 on April 25, 2018 at 3:59 AM
  This message has been viewed 296 times.
In Reply To Any reason NOT to crack 19mm intake cam bolts before... posted by GrecV2 on April 23, 2018 at 10:32 PM
Message I usually loosen the cam bolts with an impact wrench while the belt is still on the motor.
Note you will be able to torque the exhaust cam bolts with the belt re-installed, but you will need to torque the intake cam bolts BEFORE installing the new belt.
