TwinTurbo.NET: Nissan 300ZX forum - Exactly the way to do it. Documented it in a supplemental
Subject Exactly the way to do it. Documented it in a supplemental
Posted by jzack on April 23, 2018 at 11:45 PM
  This message has been viewed 312 times.
In Reply To Re: Any reason NOT to crack 19mm intake cam bolts before... posted by GrecV2 on April 23, 2018 at 10:35 PM
Message 120k auto-FAQ that I authored (lol, years ago). Use a c-clamp on each exhaust gear to insure no belt tooth jumps. Works fine - nothing moves. This assumes you have manual tranny in gear or if an auto tranny you've prevented crank from moving (i.e.., using a screw driver or similar to engage the flywheel tranny gear).
Auto FAQ: [ http://www.twinturbo.net/nissan/300zx/forums/technical/view/1054425/Supplemental-Notes--120k-T-Belt-Servicing.html ]
Probably should re-host the pix and ask Damon to repost.
