TwinTurbo.NET: Nissan 300ZX forum - Possibly a vacuum leak somewhere
Subject Possibly a vacuum leak somewhere
Posted by LitlElvis on April 19, 2018 at 9:22 AM
  This message has been viewed 392 times.
In Reply To Revs not dropping immediately to idle... posted by GrecV2 on April 17, 2018 at 09:37 AM
Message and the ECU takes a few seconds to reduce the pulse rate to the idle air valve and pull the idle down. But the IAV can only reduce the idle by so much.
Unplug the IAV from the harness and see if the RPM remains at your 1.5-2K range and does not settle down. If so, see if you can manually reduce the idle via the IAV idle speed screw... if you can't, you definitely have a vacuum leak or the throttle valves are open too far.
To check for vacuum leaks, spray starter fluid around all the plenum gasket surfaces and vacuum ports while the engine is idling to see if you can find a location that makes the idle speed change.
