TwinTurbo.NET: Nissan 300ZX forum - Revs not dropping immediately to idle...
Subject Revs not dropping immediately to idle...
Posted by GrecV2 on April 17, 2018 at 9:37 AM
  This message has been viewed 495 times.
Message This issue is unrelated to the work I just did, as it was already happening before, but I'd hoped cleaning up all the connections on the plenum would fix it. Apparently not.
So... a little hard to explain, but basically what I'm seeing is that my revs don't drop straight down to idle after I let off throttle. Instead, they will drop down to about 1.5-2k... sit there for a few seconds, and then slowly settle down to 900-1k RPMs. Almost like you'd expect it to behave it it was still being choked to warm up. But this occurs at normal running temp.
Any ideas?
Former Stage V addict... off the wagon.
