TwinTurbo.NET: Nissan 300ZX forum - 2nd on this. Cheap dial gauge and stand from Harbor Freight
Subject 2nd on this. Cheap dial gauge and stand from Harbor Freight
Posted by ZXoltan on April 12, 2018 at 8:31 AM
  This message has been viewed 297 times.
In Reply To Re: Steering Wheel shake posted by Metacom on April 11, 2018 at 08:02 PM
Message will do the trick for rotors. They often have runout right from the factory, or the hub can be a little bit off. Indexing them on the hub may help, but this needs to be checked with a runout/dial gauge.
Some Z's can also be very particular about the wheel balance. You may need to have them strobe balanced on the car (if you can find someone who still knows how to do this). I had this issue on a 93 2+2 many years ago, and I needed to have the tires trued to eliminate high spots and then strobe balanced. This was the only way to get rid of the harmonic vibrations (ones occurring only between certain speeds).
However, if it occurs when braking (and not within those same speeds) its likely a rotor problem or loose suspension, as others have mentioned.
