TwinTurbo.NET: Nissan 300ZX forum - Re: Steering Wheel shake
Subject Re: Steering Wheel shake
Posted by Metacom on April 11, 2018 at 8:02 PM
  This message has been viewed 351 times.
In Reply To Steering Wheel shake posted by Johnny C on April 11, 2018 at 10:03 AM
Message check the run out of the rotors with a dial indicator. Turning rotors can sometimes make them worse if not done properly.
Out of balance tires usually results in an oscillation type of "sawing back and forth" vibration in the steering wheel. Are you NA? try swapping the rears to the front and see if it changes.
A bad knuckle would of showed up in alignments, bad rack bushings would have other effects too like poor steering return, sound/cluck from the rack moving around...and if severe enough an off center steering wheel that keeps changing.
