TwinTurbo.NET: Nissan 300ZX forum - Re: Starter Grind -- Failing Starter?
Subject Re: Starter Grind -- Failing Starter?
Posted by BenWP on April 11, 2018 at 7:01 PM
  This message has been viewed 348 times.
In Reply To Starter Grind -- Failing Starter? posted by NNayak on April 10, 2018 at 04:07 PM
Message My NA starter had the same intermittent failure to engage the flywheel. I stupidly thought the problem was the starter and bought a re-built unit. It didn't help the problem, and after the bad flywheel was replaced, the re-built still failed to engage. Then it was necessary to purchase a Denso, which works fine. Big bucks, and feeling that the original starter was probably OK. I had been advised to avoid re-built, but did not listen to advice on discussion boards.
