TwinTurbo.NET: Nissan 300ZX forum - Referring to the J pipe off the turbo outlet?
Subject Referring to the J pipe off the turbo outlet?
Posted by Zbruh92 on April 10, 2018 at 8:55 AM
  This message has been viewed 283 times.
In Reply To How tight does lower boost hard pipe need to be clamped? posted by GrecV2 on April 09, 2018 at 12:44 PM
Message Sounds like you should be fine I wouldn’t second guess your work. I had the same concerns with mine on the passenger side, ended up overtightening it n twisting the clamp. Even then it still sealed fine no leaks. In any case, on the driver side I force my hand between the booster and fuel lines and under the master cylinder. I use a 1/4” drive ratchet w/o extensions and hand it to myself from above.
