TwinTurbo.NET: Nissan 300ZX forum - Re: Tools for rusted exhaust bolts and studs?
Subject Re: Tools for rusted exhaust bolts and studs?
Posted by ouikikazz on April 09, 2018 at 3:42 PM
  This message has been viewed 280 times.
In Reply To Tools for rusted exhaust bolts and studs? posted by nelso419 on April 07, 2018 at 09:23 PM
Message torch is your best bet usually...you can also force a socket that is smaller than the actual diameter onto it (hammer and persuasion)...try to use a socket that is 6 sided not 12 sided and then use lots of rust penetrating lube then get a really good breaker bar and then a really long pole for leverage, but in the end you'll probably still need a bit of heat from a torch to just break up a little of that rust and it'll get you started.
