TwinTurbo.NET: Nissan 300ZX forum - They are used to remove any sway bar preload
Subject They are used to remove any sway bar preload
Posted by ttsmokin on April 07, 2018 at 8:00 PM
  This message has been viewed 327 times.
In Reply To Does anyone actually use adjustable sway bar end links? posted by jgbatlantaZ on April 07, 2018 at 07:17 PM
Message You want the end links to be able to be installed without any preload on the sway bars when the vehicle is on level ground. You also have the ability to change sway bar angle.
The different holes on the aftermarket sway bar allows you to tune the setup. Allows suspension to apply more or less leverage on the sway bar.
