TwinTurbo.NET: Nissan 300ZX forum - Correct me if I'm wrong
Subject Correct me if I'm wrong
Posted by Placuch on April 05, 2018 at 5:46 AM
  This message has been viewed 343 times.
In Reply To Alignment Spec Question posted by S2z on April 04, 2018 at 06:13 PM
Message When toe in/out measurement is given as distance (inches or mm) it means total toe because of the manner of how it's measured. When the measurement is in degrees, it could be both total or per wheel but it will be specified. Degree measurements for toe are most times generated by alignment racks using electronic wheel sensors.
Correct alignment setting will depend on personal preference and many factors on the car. 3 degree camber and 1/8 in toe is a good starting point and I wouldn't be worried about getting 1/8 in tow out per side vs 1/16 in. It's still little and you may have to change it to find your preference.
