TwinTurbo.NET: Nissan 300ZX forum - clutch still not disengaging.
Subject clutch still not disengaging.
Posted by Boostjuice on March 30, 2018 at 7:28 PM
  This message has been viewed 363 times.
Message replaced clutch slave cylinder and bled, car still won't go into gear with engine running. car goes into gear with engine off. both the master cylinder and slave cylinder are new, pivot ball is new, throwout bearing is new, heavy duty clutch fork is new, RPS max street clutch with 1500 miles on it, clutch pedal is firm, adjusted pedal per specialty z write up. car was driving fine, never smelt burnt clutch, or no slipping of the clutch, put about 1500 miles on, was in 2nd, went into 3rd and when I went to go into 4th it was blocked, and then all the other gears were blocked, stopped, turned the car off put into gear and the car lurches forward with the clutch pedal depressed, clutch not disengaging. any ideas? when was RPS having a problem with pressure plates, I bought this clutch in 2015 when gathering parts for my build.
