TwinTurbo.NET: Nissan 300ZX forum - Is the #5 spark plug wet with fuel at all after running it
MixManMash
on March 25, 2018 at 2:00 PM
1990 TT Ignition Issue
posted by delmo
on March 24, 2018 at 06:05 PM
for a while? If not, then I suspect bad fuel injector or a problem with the wiring. I also recommend making sure the connector on the ECU is seated all the way in on the extreme ends.
delmo
18:05:51 03/24/18
Ohm check the Injectors..~12 Ohm (n/m)
Cjw3
18:17:37 03/24/18
Issue with the PTU adapter harness would be another
jzack
18:41:16 03/24/18
if The injectors and harness check out test the ptu itself
Zbruh92
04:31:23 03/25/18
Is the #5 spark plug wet with fuel at all after running it -
MixManMash
14:00:58 03/25/18
Re: 1990 TT Ignition Issue
delmo
10:11:52 03/26/18
