TwinTurbo.NET: Nissan 300ZX forum - Re: BTW - another way to test. Leave gas cap tight, idle car
KY Z MAN
on March 14, 2018 at 1:15 AM
posted by jzack
on March 13, 2018 at 10:26 PM
I tried the gas cap test but here's where it gets weird started it up it ran for one hour did no quit on me but the temp outside was twenty five degrees will try tomorrow when its supposed to reach 50. will let you know, thanks for your help.
Code 21 ISC
KY Z MAN
00:46:41 03/13/18
Sounds as if you looked at all the right things. Give this
jzack
09:50:26 03/13/18
Re: Sounds as if you looked at all the right things. Give this
KY Z MAN
13:57:41 03/13/18
Generally not easy to fry. One cause can be failure to
jzack
14:13:07 03/13/18
Re: Generally not easy to fry. One cause can be failure to
KY Z MAN
14:49:41 03/13/18
The sitting 1 hour is also a good clue - leads me to believe
jzack
18:07:40 03/13/18
But it's positive pressure pump in the tank system
compirate
20:28:35 03/13/18
Lol, very easy. The tank has a vapor return line.
jzack
22:13:11 03/13/18
jzack
22:26:21 03/13/18
KY Z MAN
23:17:44 03/13/18
Re: BTW - another way to test. Leave gas cap tight, idle car -
KY Z MAN
01:15:23 03/14/18
But not technically vapor lock, more a vacuum lock,
compirate
01:00:25 03/14/18
Yep, agreed. (n/m)
jzack
00:31:34 03/15/18
Re: Lol, very easy. The tank has a vapor return line.
KY Z MAN
21:52:14 03/14/18
KY Z MAN
14:56:52 03/13/18
KY Z MAN
21:58:20 03/14/18
