TwinTurbo.NET: Nissan 300ZX forum - Re: Generally not easy to fry. One cause can be failure to
Subject Re: Generally not easy to fry. One cause can be failure to
Posted by KY Z MAN on March 13, 2018 at 2:49 PM
  This message has been viewed 390 times.
In Reply To Generally not easy to fry. One cause can be failure to posted by jzack on March 13, 2018 at 02:13 PM
Message Yes sir john I just put a Nissan factory temp sensor on it. but when I soldered those six wires that run in front of timing belt cover cut the plugs off an soldered them when I cut them back as far as I could the wire was black under the insulation. could that be causing signal flow problems.
