TwinTurbo.NET: Nissan 300ZX forum - Stuck on plenum removal... EGR Return Tubes
Subject Stuck on plenum removal... EGR Return Tubes
Posted by GrecV2 on March 10, 2018 at 1:40 PM
  This message has been viewed 386 times.
Message Following the steps on the tech doc: [ http://www.twinturbo.net/nissan/300zx/tech/plenum/plenum.aspx ]
I’m currently on step 14…
4x12mm bracket bolts are out, but I can’t for the life of me find the 4x10mm bolts to disconnect the EGR Feed Tubes… it references the “green dots in 19” but that can’t be right, as 19 shows the hoses from step 12.
I’ve already removed the 4x10mm bolts holding the EGR Return Tubes from step 13, (just behind the throttle bodies, facing down) but can’t find these… :-\
Where should I be looking?
Former Stage V addict... off the wagon.
