TwinTurbo.NET: Nissan 300ZX forum - That's a loaded question.
Subject That's a loaded question.
Posted by MixManMash on February 20, 2018 at 3:08 PM
  This message has been viewed 343 times.
In Reply To Re: Sounds like a failed turbo. posted by Lowlife1998 on February 19, 2018 at 10:10 PM
Message In order to convert back to NA, you need to know how the conversion to TT was done.
If the engine used is the NA engine (high compression), then you likely could, but you will need the exhaust headers, NA ecu or chip, injectors (270cc). That's at a minimum. You could get away with the larger injectors if the ECU chip is remapped for the larger injectors.
If the engine used is the TT engine (lower compression), I wouldn't recommend it. It won't make much power with the lower compression pistons, and to do it, you would likely need a custom tune.
Try doing a compression test on your engine as well. Make sure it really is a failed turbo before going too crazy.
