TwinTurbo.NET: Nissan 300ZX forum - The lockup solenoid is usually to lockup the
Subject The lockup solenoid is usually to lockup the
Posted by MixManMash on February 19, 2018 at 7:15 AM
  This message has been viewed 281 times.
In Reply To Auto transmission code posted by Bigmatthew86 on February 18, 2018 at 07:29 PM
Message torque converter. It typically locks up once at speed. It helps with fuel economy as the torque converter essentially being a fluid clutch has significant losses. When it locks up, it is directly coupled with the engine.
You should check continuity of the wiring harness to the solenoid using a multimeter and the solenoid itself. If the solenoid is open circuit, it has likely failed.
