TwinTurbo.NET: Nissan 300ZX forum - ES Tension Rod Bushings
Subject ES Tension Rod Bushings
Posted by jezebel on February 01, 2018 at 3:36 PM
  This message has been viewed 416 times.
Message I apologize in advance if I've overlooked the answer, but I've been searching and can't find anything newer than a few years on this subject.
Currently, I have the SPC adjustable T-rods, which while great for adjustability, the rubber is tearing after less than 2 years (yes, they were installed correctly). I would like to use the same rods but replace the bushing with ES poly ones.
ES supposedly redesigned the T-rod bushings to address some issues involving breakage of the T-rod or lower control arms.
My question is, are these recommended replacements now and if so, what was the design change that fixed the issue?
