TwinTurbo.NET: Nissan 300ZX forum - I had to crack the line at the master cylinder
Subject I had to crack the line at the master cylinder
Posted by Polish on January 23, 2018 at 4:35 PM
  This message has been viewed 383 times.
In Reply To Clutch Bleeding Woes - Good pressure but pedal travel is bad posted by Polish on January 15, 2018 at 04:24 PM
Message I had someone pump several times, and cracked it right there. I also cracked it before pumping at all, had someone pump once slowly and hold, then re-tightened. Definitely saw some air-splatter come out with the brake fluid. IMMEDIATE difference in clutch pedal. Also had to adjust rod more, but now it feels good. Thanks for all your help!
