TwinTurbo.NET: Nissan 300ZX forum - If you test the fuel rail and injectors as a closed loop>>
Subject If you test the fuel rail and injectors as a closed loop>>
Posted by ZUL8TR on January 23, 2018 at 5:57 AM
  This message has been viewed 407 times.
In Reply To Re: Testing fuel injector after install posted by brian913 on January 20, 2018 at 09:18 AM
Message with compressed air make sure the compressor does not have leak back during the test. To insure a positive test with no compressor leak back have a valve on the compressor supply so it can be closed once the fuel rail and injectors are pressured up to about 50 psi. Then let the set up sit in the water bath for some time I used about 1 hour when I replaced my injectors.
ZUL8TR
