TwinTurbo.NET: Nissan 300ZX forum - Re: Still getting the codes after
Subject Re: Still getting the codes after
Posted by tian2bing on January 18, 2018 at 10:29 AM
  This message has been viewed 385 times.
In Reply To Still getting the codes after posted by compirate on January 16, 2018 at 04:20 PM
Message well, I reconnect the connectors. Drove about 50 miles. No code..
Does that mean it is fixed? something like a loose connector?
:you plugged the connector back? Could be a bad connection too.
:Code 22 is short circuit and Code 21 is open circuit.
:Check the resistance (0.8-1.2KOhms) on Pin 21 and 23 on the harness connector at the controller. Looking at the end of the connector, the right side will be rounded. Pin 21 is the third from the left, bottom row. Pin 23 is two more further right
