TwinTurbo.NET: Nissan 300ZX forum - I've never done an Auto to Man Conversion
Subject I've never done an Auto to Man Conversion
Posted by Cjw3 on January 16, 2018 at 10:08 AM
  This message has been viewed 375 times.
In Reply To Clutch Bleeding Woes - Good pressure but pedal travel is bad posted by Polish on January 15, 2018 at 04:24 PM
Message However I've gotten my A$$ Kicked bleeding a few 300 Cluthes..
FOR ME.. I have a herd time getting the Air Bubble out of the LARGE Tube on the Fender.. On two of my 300's I've removed that tube from the Block next to the frame rail, and Bleeding in now a Snap..
My other 300's that still has the Tube.. It requires three people..
One person at the Peddle, One at the Slave, One at the Fender Bleeder..
1) Bleed as Normal and get as much air as you can out.
2) For the 'Last Few Bleedings' Have the 'Peddle Pusher' Start pushing Down, as a Person on the Slave Cylinder Pushed it into the Cylinder and the person on the Fender Bleeder opens the Bleeder Vent..
I'm thinking all the Oil/Fluid rushing so fast through the Large Tube pushes the Air Bubble out..
FOR ME, the only way I've been able to get the Fender Tube out is by Pulling the Engine.. So on my Two of Three 300's that I've had the Engine out of.. that tube was also removed.. I've not been able to get the angle proper to get a wrench on the Tubing Block next to the Frame Rail by the Starter to get the tubing Nut off any other way..
Cj
