TwinTurbo.NET: Nissan 300ZX forum - Sorry, just used to these things dying off with no
Subject Sorry, just used to these things dying off with no
Posted by compirate on January 08, 2018 at 9:02 AM
  This message has been viewed 436 times.
In Reply To Well, I didn't simply try changing the bulb. posted by FrozTTy on January 08, 2018 at 07:46 AM
Message resolution. I hear you about the 0 degrees! Haven't had water for a couple days because of it. "Inspecting" the relay can be removing it and seeing if the light goes out completely, or listening for it to click after the light has dimmed. Can also see if one of the relays under the hood is similar and temp replace it with that. Also can remove the relay and put 12v on the correct to pins and see if it clicks. Also can check continuity on the contacts to see if it's releasing or not.
Stay warm till Friday!
