TwinTurbo.NET: Nissan 300ZX forum - Aside from the antitheft control unit, you've got several
Subject Aside from the antitheft control unit, you've got several
Posted by compirate on January 03, 2018 at 1:24 PM
  This message has been viewed 517 times.
In Reply To I said they do go out posted by FrozTTy on January 03, 2018 at 12:40 PM
Message sensors needed to arm the system -
Hood switch
Door Jam switches
Deck lid switch
Door lock actuator switches
Door key lock switches
Door key lock tamper switches
If the interior light isn't going out completely, I'd check the door jam switches first, perhaps they aren't working right. That will definitely keep your alarm from setting because it thinks a door is still open. I don't know if the switch has continuity when it's pressed or released. Remove the cover and one fastener holds it in. Pull it out and unplug the connector. See if the light goes out completely then. If it doesn't dim at all, then rig a wire between the two connectors on the plug and see if it goes out then. It could be the one on the other side too, but I would think the drivers side would wear faster due to use.
