TwinTurbo.NET: Nissan 300ZX forum - Blinking Security Light and Dome Light Operation
Subject Blinking Security Light and Dome Light Operation
Posted by FrozTTy on January 02, 2018 at 9:15 AM
  This message has been viewed 702 times.
Message I posted a while back regarding my security light on the dash. It would stay blinking after doors were shut and Z was locked. Tested the alarm and it doesn't work properly.
My security light has since burned out.
I've always kept my dome light "off" as I rarely need/use it. The other day I tested it to make sure it's still working. Flipped to the "door" position and it would come on with door open but when I shut the door it would dim, but stay on. Kept trying several more times to see if worked properly, and didn't. Switched back to "off" and light stays off as it should.
Question - are the blinking security light and this improper dome light function related?
My hood switch is brand new (and won't effect dome light anyway - just the security).
When security light was blinking, I could turn it off by rotating the key in each and every key slot (driver and passenger doors and trunk) which noted those are operating as they should be.
HELP
THANKZZZ
