TwinTurbo.NET: Nissan 300ZX forum - I had Nissan check ignition timing after my rebuild
Subject I had Nissan check ignition timing after my rebuild
Posted by Zbruh92 on November 15, 2017 at 1:22 AM
  This message has been viewed 436 times.
In Reply To Any recommendations in MN for an initial tune? posted by ZUL8R on November 14, 2017 at 10:16 AM
Message They told me it was spot on and that my rear control arms were leaking oil.... but they have conZult and let me in the garage while they checked it.
Once you get timing set it helps to mark its position for future reference. The Idle is pretty easy to set the hardest part is getting the connector off and the AFR is controlled via ECU and should be correct if everything else is functioning properly. A lean mixture would cause it to run warmer u can run o2 diagnostic on the ecu for peace of mind. Stock or aftermarket temp gauge? What are your plugs gapped to?
