TwinTurbo.NET: Nissan 300ZX forum - If you go thru the trouble to remove, might as well replace
Subject If you go thru the trouble to remove, might as well replace
Posted by jzack on November 02, 2017 at 10:33 PM
  This message has been viewed 363 times.
In Reply To Cleaning your IACV is a good start (n/m) posted by -Grimm- on November 02, 2017 at 02:56 PM
Message it. It could be just stuck or it could really be busted.
FYI - once engine is full warmed up, use some locking piers to pinch closed the longer hose that connects to the balance tube at mid-section. If idle drops you've found the issue. BTW - idle should be in the 750-775 rpm range with AC off.
