TwinTurbo.NET: Nissan 300ZX forum - Re: Re: 300ZX tt idle searching
Lowlife1998
on November 02, 2017 at 9:04 PM
posted by Metacom
on November 02, 2017 at 08:06 PM
Could it be cleaned or does it have to be replaced? And what’s a normal idle? All the zs I’ve had idled at around 1k
Lowlife1998
13:51:02 11/02/17
Cleaning your IACV is a good start (n/m)
-Grimm-
14:56:05 11/02/17
Re: Cleaning your IACV is a good start
Lowlife1998
15:20:39 11/02/17
If you go thru the trouble to remove, might as well replace
jzack
22:33:10 11/02/17
Re: If you go thru the trouble to remove, might as well replace
Lowlife1998
15:14:10 11/03/17
Could be that the TPS is out of adjustment or the idle
jzack
21:03:17 11/03/17
Re: Could be that the TPS is out of adjustment or the idle
Lowlife1998
11:40:48 11/04/17
Lowlife1998
15:16:19 11/03/17
Metacom
20:06:24 11/02/17
Re: Re: 300ZX tt idle searching -
Lowlife1998
21:04:17 11/02/17
Should be ~750RPM for a 5sp if I am not mistaken
-Grimm-
12:41:05 11/08/17
