TwinTurbo.NET: Nissan 300ZX forum - A/C Idler Pulley Bearing
Subject A/C Idler Pulley Bearing
Posted by Borg79(ON) on October 28, 2017 at 6:49 PM
  This message has been viewed 390 times.
Message Changed the bearing on the A/C idler pulley tonight. Rather than buy the whole pully/tensioner assembly I bought and pressed the bearing (old one was noisy). For anyone else in the same boat, I found the correct bearing to be an SKF 6301-2RSH/C3 (around $10 vs $100+ for the whole pulley).
Cheers
-"Chains baby, chains.......Z will grip like a champ. (n/m) - Wolf [Pittsburgh] 14:56:58 05/10/00"
How to Check Turbos: "1st remove exhaust and pre-cats. Then fire that mother up, rev it to at least 5000 rpm and then stick your finger into the hole on the back of the turbo. If the turbine grinds your finger down, then your turbo is working. If your finger gets ground off farther than the second knuckle, then your turbos are good for at least another 60k miles! Don't forget to check both sides." -I am Z-ing Double
-"The world's two biggest mysteries: The meaning of life and fitting the Howe radiator into the Z..." -Seedyrom, circa 2000
