TwinTurbo.NET: Nissan 300ZX forum - Re: Only 5psi in 2nd gear, but 10psi in 3rd?
Subject Re: Only 5psi in 2nd gear, but 10psi in 3rd?
Posted by nzryan on October 24, 2017 at 1:40 AM
  This message has been viewed 345 times.
In Reply To Only 5psi in 2nd gear, but 10psi in 3rd? posted by P-Suth on October 23, 2017 at 09:15 AM
Message if it is a boost leak of that much, you will see a lot of black smoke out the tail pipes at the same time,(perhaps when you do it, have a quick glance out the rear vision mirror and see if your blowing clouds of black smoke). I've had a boost leak before that took some heat and pressure to show (and it did make noise when it did it too), it turned out to be a loose hose clamp and the silicone joiner would make the noise as it ~flapped~ while leaking.
