TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: 17.7v seems way off but let's reverify the measure. DO NOT
Subject Re: Re: Re: 17.7v seems way off but let's reverify the measure. DO NOT
Posted by NIVO88T on October 20, 2017 at 10:32 AM
  This message has been viewed 343 times.
In Reply To Re: Re: 17.7v seems way off but let's reverify the measure. DO NOT posted by TheKryptKeeper on October 16, 2017 at 10:19 PM
Message There is a 12V circuit that runs into the dash for the bulb, I believe it's white/red wire. runs into the bulb check relay and then to the actual bulb. if either the relay or the bulb is not working the alternator will not charge.
if you have the bulb out of the socket it will not charge, if the bulb is blown it will not charge, if the bulb is LED it will not charge.
